Date/Time: Sat, 18 Jan 2025 07:55:34 +0000
Simple bracket keeps being be adjusted
View Count: 556
[2018-02-01 16:18:28] |
User118960 - Posts: 16 |
Hi, When I'm simulating my strategy it will keeps adjust my profit and loss targets to 1 point. Did looked up into the settings but can't find anything |
[2018-02-01 18:21:53] |
From our perspective this is not clear what exactly you are describing. We need to have a lot more surrounding context. For example, is an existing order getting modified? If so, why is that the case? We would not know the answer to that. You are a far better position to answer this than us. Or what exactly are you referring to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-01 18:23:03
