Date/Time: Sat, 18 Jan 2025 08:00:23 +0000
Bad Color Numbers Bars after updating to version 1689
View Count: 666
[2018-02-01 09:02:13]
User68117 - Posts: 65
I have a question about updating. We had version 1625 and updated to version 1689.
Totally I decided to change the Numbers Bars again. Look in the attachment. I have the same settings, but the color is different. This has already happened in previous updates, but Column 1-3 Percent Compare Thresholds has always been set up correctly. But now it is not possible.
So what's the solution for me to have the coloring back like the 1625 version?
image1625.jpg / V - Attached On 2018-02-01 09:01:49 UTC - Size: 458.49 KB - 278 views
image1689.jpg / V - Attached On 2018-02-01 09:01:55 UTC - Size: 393.39 KB - 307 views
[2018-02-01 19:00:43]
Yes, there have been changes to the Numbers Bars in order to make them more consistent. We understand what you are looking for here and we will create a new Text Coloring option called Based On Separate AskVol BidVol Percentage. This will perform the same calculation as the Based On AskVol BidVol Percentage, but the text on both sides of the Bid and Ask will be colored, regardless of dominance.
This will be out in a day or two.
