Date/Time: Sat, 18 Jan 2025 07:50:02 +0000
add horizontal lines to Overlay (Bar) study
View Count: 988
[2018-02-01 06:03:23]
whats1thingnow - Posts: 407
From this https://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#Overlaying, I implemented:
If you have a market statistics chart that you want to overlay in the study region of another chart, then this can be done by using the Overlay (Bar) study. For example, maybe you want to overlay the TICK-NYSE chart below another chart.
To do this you will need to add the Overlay (Bar) study to your destination chart. Set the Chart Number to Overlay Input to the chart that you want to overlay which is going to be the market statistics chart which also needs to be in the same Chartbook.
Now I have the NISS-NYSE (region 2) and TICK-NYSE (region 3) underneath my /ES chart.
However, I want to add some horizontal lines in region 2 and region 3. For example, I want to add a line at 0, 1000, -1000, 1500, -1500 for NISS-NYSE (region 2).
However, when i tried to use the "Horizontal Lines" study and use it on region 2, it's not using the same scale as NISS-NYSE.
How do i add lines to NISS-NYSE in region 2?
Thanks!
[2018-02-01 19:51:41]
Follow the instructions here:
Chart Studies: Adding a Horizontal Line to an Existing Study
