Date/Time: Wed, 19 Mar 2025 02:42:07 +0000
ASX Data only reqd. for spreadsheet, similar to Googlefinance
View Count: 1012
[2018-02-02 03:26:10] |
ASX stock Data delivered via cloud/internet Yes. This will be provided by the Sierra Chart Historical Data Service:Sierra Chart Historical Data Service An accessible through the DTC Protocol Server: Data and Trading Communications (DTC) Protocol Server ASX Indices. The only index is the AUS200 provided with this particular service:Sierra Chart Real Time and Historical Forex and CFD Data Service Only require up to the last 30 days of historical data. Yes this is available.These fields are available: Open, high, low, close, volume,
EOD data only reqd. but on the current day have the current data updating once every few minutes (eg updating every 10 minutes?) There would be no automatic updating but we may be able to have the data update every 20 minutes but that is going to require also using the Sierra Chart Exchange Data Feed for just the data connection of 25USD a month:Sierra Chart Exchange Data Feed Data to go into a standard spreadsheet, if not, then SC spreadsheet but I need data on one sheet to list all the ASX codes and OHLC etc. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-02 03:27:04
