Date/Time: Sat, 18 Jan 2025 07:45:51 +0000
Configure Reward Risk Dollar Calculation
View Count: 1022
[2018-02-01 03:44:09] |
Fuming - Posts: 10 |
Where do you configure how the Reward Risk tool calculates P/L dollar amounts? Initially this seems to have been working as expected. But I must have done something to throw it off, because now 1 tick is calculating as $125 move.
[2018-02-01 18:39:54] |
Refer to the documentation here: Chart Drawing Tools: Reward/Risk Configuration Specifically to Show Currency Value. Probably it is the Trade Window Order Quantity affecting this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-01 18:41:39
