Date/Time: Sat, 18 Jan 2025 05:13:52 +0000
Market Depth in Sierra Chart historical data
View Count: 618
[2018-02-01 00:34:54] |
User202045 - Posts: 11 |
If I'm reading the documentation correctly, I need to be connected to a real time data feed to get market depth. So the studies in the SC advanced historical data feed that rely on market depth will not work unless I'm also connected to a real time feed. Is that correct?
[2018-02-01 02:38:00] |
Yes but this assumes the particular data feed is going to provide market depth data for the particular symbol you require it for. Refer to: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-01 02:38:11
