Date/Time: Sat, 18 Jan 2025 07:51:03 +0000
Custom windows/Forms
View Count: 1187
[2018-01-31 21:40:41] |
User701453 - Posts: 176 |
Can ACSIL code be use to create custom forms/windows that can have buttons,textboxes and such? That will also interact with the platform and display chosen data from a chart. I know its possible with Tradestation and Ninja, just don't know if Sierra has that ability. |
[2018-02-01 02:28:29] |
This is explained here: ACSIL Programming Concepts: Use of Dialog Windows in Advanced Custom Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-01 13:09:53] |
[2018-02-01 18:13:29] |
Do not say thank you.
