Date/Time: Sat, 18 Jan 2025 07:56:09 +0000
US30 cfd works badly
View Count: 949
[2018-01-31 18:04:57] |
Cyberdogk9 - Posts: 27 |
Hi, for some reason I have strange problems with US30. It loads when you open it as new window but when I want to change chart type to renko bars it reload but stops at 13% and nothing in the log file about that. Restarted program, computer, deleted and reloaded data but without anything. Can you check it out? Is it ok on your part? And if it not big trouble please check data for spx500 there was some bugs in quotes at 10 am est. |
[2018-01-31 18:18:39] |
This has been resolved. Update Sierra Chart to the current version following the instructions here: Software Download: Fast Update We see nothing unusual with the SPX 500 data 2018-1-31. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-31 18:31:58] |
I understand that it's just a cfd, but it doesn't look right.
SPX500 [M] Renko 4t #4 2018-01-31 13_26_17.860.png / V - Attached On 2018-01-31 18:30:49 UTC - Size: 91.56 KB - 246 views |
[2018-01-31 20:19:07] |
Make sure you are running the current version of Sierra Chart. Make sure the Tick Size for the chart is set correctly and that the Price Display Format also corresponds to that tick size setting. Refer to: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) If you still see this, then the result is correct based upon the Renko setting and the price data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-31 20:19:38
[2018-02-02 12:27:57] |
Again I see bad quotes. This is a regular thing. Version is the latest and everything is ok.
SPX500 [M] 15 Sec #10 2018-02-02 07_24_16.476.png / V - Attached On 2018-02-02 12:26:50 UTC - Size: 90.71 KB - 252 views |
[2018-02-02 17:01:50] |
That is the data provided by FXCM. It is simply what it is. If you want the actual exchange data, then refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-02 17:02:33
