Date/Time: Sat, 18 Jan 2025 05:06:57 +0000
summation of up volume and down volume studies
View Count: 904
[2018-01-31 17:08:07] |
Glenn Infinity - Posts: 103 |
can you tell me how to do this? I have a study on my chart called Up Volume (ID:6-SG1) another study called Down Volume (ID:4-SG1). I would like to be able to sum those volumes like the study Zig Zag Cumulative Volume indicator does. How would I go about doing this? Thanks |
[2018-01-31 18:29:04] |
This is supported with this particular study: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
