Date/Time: Sat, 18 Jan 2025 05:20:29 +0000
Windows are always minimized
View Count: 973
[2018-01-31 15:34:45]
User63769 - Posts: 35
Every time I open Sierra Charts, all windows are minimized except a spreadsheet window. To restore my windows I must double click on the minimized window that I want.
This happens despite saving my windows in a maximized format before quitting the application.
This started happening after I used the Hide Window command from the Window menu.
imageSierra Chart after opening.PNG / V - Attached On 2018-01-31 15:33:12 UTC - Size: 74.77 KB - 254 views
[2018-01-31 17:41:21]
Most likely an operating system issue but attach the Chartbook, and we will see what we notice when opening it.
Follow the instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2018-01-31 18:30:29]
Here is the chartbook.
attachmentAUTO TRADING.cht - Attached On 2018-01-31 18:29:54 UTC - Size: 2.78 MB - 307 views
[2018-01-31 20:23:55]
When we opened this Chartbook, all 3 charts contained within it were hidden because you must have made them hidden.
We restored and maximized one of them and saved the Chartbook and reopened it and that one that was restored, did open up visible and maximized.
You may also want to change the state of this setting to see if it makes any difference:
General Settings Window: Destroy Chart Windows when Hidden (Global Settings >> General Settings >> GUI >> Application GUI)
Date Time Of Last Edit: 2018-01-31 20:24:09
