Date/Time: Fri, 31 Jan 2025 13:55:09 +0000
[User Discussion] - Daily OHLC->session
View Count: 1644
[2018-01-31 09:06:27] |
User33743 - Posts: 83 |
Hi, Daily OHLC is a great study but for some instruments additionally, study for Session OHLC would be as good. I know that i can have result for session by changing session Time in chart settings but then it would change initial DAILY OHLC. I would like to have both information Daily OHLC and Session OHLC at the same time but session open/close is not at same time as daily open close . Is there an existing study that can do session time separately? If is not would you consider creating this study? It just requires small changes in DAILY OHLC; * not using session time from chart settings *creating fields to input time for Open/ close and high/low based on this period of time |
[2018-01-31 11:30:59] |
User907968 - Posts: 825 |
Have you considered the 'High/Low for time period extended' study? I believe that this can be setup to do what you are asking. Alternatively, you could (for example) create daily charts - 24hr, RTH and ETH, apply the OHLC study to each of these charts and then overlay onto your chart(s) of choice. |
