Date/Time: Sat, 26 Sep 2026 18:47:22 +0000
[Programming Help] - SC_RENKO_CLOSE sometimes return zero
View Count: 1073
[2018-01-31 04:02:51]
User841591 - Posts: 42
I get the close price as the code below and use (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED && BuyTiggerLogic) to trigger the buy order. I sometimes find the NewOrder.Price1 get zero value and sometimes is correct. Pls advise how I can fix it.
SCFloatArrayRef R_Close = sc.BaseData[SC_RENKO_CLOSE];
NewOrder.Price1=sc.RoundToTickSize(R_Close[sc.Index]-sc.TickSize);
int Result = sc.BuyEntry(NewOrder);
[2018-01-31 04:15:53]
The first thing we want you to do is to update to the current version of Sierra Chart following these instructions:
We would not expect this to be a problem.
[2018-01-31 05:13:06]
I am using version 1674
[2018-01-31 05:23:31]
We told you to update to the current version and we expect you to do that.
[2018-01-31 09:16:59]
I have updated the current version but problem still happen
[2018-01-31 23:44:11]
The only known case where these values can be 0 is only on a new bar for the day when using Aligned Renko bars.
If you are seeing this with prior bars, there must be something wrong in your code. And you can verify this is by using the Chart Values tool and looking at what these values are for each bar at any moment. Refer to:
Renko Bar Charts: Renko Open, High, Low, Close Values
When they are 0 you need to alternatively use SC_LAST instead.
