Date/Time: Sat, 18 Jan 2025 05:00:30 +0000
Bulk Intraday Data Download
View Count: 812
[2018-01-30 20:24:53]
like2trade - Posts: 117
I understand that this is now only for internal use. A long time ago when this feature was available, I populated it with symbols. I am now doing a trial and when I start Sierra, it is hanging because it is trying to process these symbols. I need to clear these symbols out. Is there a configuration file that this is stored in that I can edit? I do not want to delete and reinstall Sierra because I do not want to go through and manually reset so many default colors etc. that I have pre-configured.
Thank you.
[2018-01-30 23:34:24]
Really what we think you are referring to is the Global Settings >>Intraday File Update List which is documented here:
Global Settings Menu: Intraday File Update List (Global Settings menu)
[2018-01-31 07:29:08]
ticinotrader - Posts: 397
Should I leave this symbol list window open to be able to continually collect intraday data?
[2018-01-31 23:34:01]
No, it does not have to be open.
Date Time Of Last Edit: 2018-01-31 23:34:06
