Date/Time: Sun, 24 Nov 2024 04:04:38 +0000
Charts not advancing to next bar
View Count: 1287
[2013-09-24 14:05:19] |
User39653 - Posts: 11 |
Using TD ameritrade data feed for stocks. I am recieving data but the charts stay on one bar. If this is an Ameritrade problem is their a way to report it to them? Also get an error downloading intraday charts. First time to see this problem As of 11:00 it appears to be working Date Time Of Last Edit: 2013-09-24 15:18:59
[2013-09-24 16:11:03] |
The relevant help topic for this is 3: http://www.sierrachart.com/index.php?l=doc/helpdetails3.html And 7: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-24 16:12:15
