Date/Time: Sat, 18 Jan 2025 05:15:23 +0000
[User Discussion] - Datafeed and Broker
View Count: 656
[2018-01-30 15:42:48] |
User203925 - Posts: 40 |
I am currently using Global Futures / CQG as my broker / data feed. I have had some issues with them in regards to my data connection. Does anyone have any recommendations of a good / reliable broker / data feed?
[2018-01-30 18:24:27] |
Refer to this section here: CQG Trading Platform Service: Frequent Server Disconnections when Using CQG Also, use prerelease 1694 and use the CQG FIX Trading connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
