Date/Time: Sat, 18 Jan 2025 04:52:08 +0000
Daily OHLC study, Number of Days To Calculate not working?
View Count: 823
[2018-01-30 14:23:19]
whats1thingnow - Posts: 407
reference: This Input sets the number of days to draw Daily OHLC lines across, starting from the end of the chart. (https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=137&Name=Daily_OHLC#Inputs)
i'm using this on my TPO chart and i have the following inputs:
Use this Intraday Chart = Yes
Reference Days Back = 1
Number of Days To Calculate = 1
the expected behavior is that i would only see 1 day to draw Daily OHLC lines across, starting from the end of the chart.
however, i see daily OHLC lines on every TPO for as far as i can scroll back.
thanks for the help!
[2018-01-30 18:42:42]
With these settings, we are unable to reproduce the problem you are seeing. The Daily OHLC lines are only displayed on the most recent day.
The first question I would ask you is whether you are seeing the Red and Green line on the previous days charts and if those are the Initial Balance Range lines from the TPO study, rather than the Daily OHLC study. To ensure you are seeing the correct lines, change the colors of the Daily OHLC study lines to non-standard colors to ensure you are seeing the correct ones. You can find documentation on how to change the subgraph colors here:
Color Settings for Graph Draw Types
Also, if you really only want to see the current day OHLC lines, then you should change the setting for Reference Days Back in the Daily OHLC study to 0. You can find the information on this input here:
Daily OHLC: Inputs
[2018-01-30 20:17:34]
i got it work after playing with it.
i turned replay on, then off, then on, then off.
the lines are now working as expected
