Date/Time: Sat, 18 Jan 2025 05:06:19 +0000
How to have a constant that can then be operated on?
View Count: 774
[2018-01-30 10:15:31]
User360283 - Posts: 506
Example: Constant = 2878 the last ES High. I would then multiply it by possible correction values, 0.99, 0.97, etc.
I am currently doing this manualy. Havein a constant would hel.
Is this possible?
[2018-01-30 19:04:12]
Refer to this page:
Using the Basic Arithmetic Studies
[2018-01-30 20:42:49]
Thanks but I already use many of the arithmetic studies.
My requests was: Example: Constant = 2878 the last ES Highest High.
I would then reference the constant variable using multiple aritmetic multiply studies each with the correction values, ie. 0.99, 0.97, etc.
Having a constant vairable would let me make only 1 entry - the highest high.
Is this possible?
[2018-01-30 22:37:32]
Not totally sure what you are looking for but you can use the Line study and set its Value input to this particular constant value.
You can then use the Line study with the other arithmetic studies.
