Date/Time: Sat, 18 Jan 2025 05:08:06 +0000
Remote Build not stripping DLLs?
View Count: 1558
[2018-01-30 08:47:31]
bjohnson777 (Brett Johnson) - Posts: 284
Doing my regular maintenance and found some upgrades I need to recompile for...
The Remote Build button now produces a DLL that is 10x the previous size of my last compile (80k became 800k). My guess is strip got turned off. If the size increase was intentional, can a strip check box be added to the window?
The Analysis / Build window seems to have lost the button to open in Notepad++. Can that be returned for convenience?
[2018-01-30 19:39:38]
We made sure when using Remote Build that there is no debugging information included. There are static libraries and that probably is the reason for the larger size. Anyway we will do some further checking on this.
To open the file in the text editor this is done through Analysis >>New/Open Custom Studies File. Has always been this way.
Date Time Of Last Edit: 2018-01-30 19:39:46
