Date/Time: Sat, 18 Jan 2025 04:54:49 +0000
[Programming Help] - Alert Writing for Stochastic and MACD
View Count: 1155
[2018-01-30 01:33:27] |
User352147 - Posts: 3 |
I'd like to write an Alert that includes Stochastic and MACD movements and specifically slope values for both indicators which will encompass positive values or negative slope values. For example, if fast Stochastic line is moving in a down (short) direction, then the slope is negative for this alert formula. Please keep in mind that the slope is either positive or negative and will cover a range of time for the duration of the short or long run (as indicated in this example). I'd like to write the same formula for MACD line values and again by using positive and negative slope values. I really appreciate your help to anyone who can help me. Thank you, Jeff Kirsch |
