Date/Time: Sat, 18 Jan 2025 04:57:37 +0000
zones
View Count: 1389
[2018-01-29 22:05:14] |
User807026 - Posts: 86 |
Is there an indicator or study for SC that allows the quick drawing of multi-tick zones? I couldn't find one but I just wanted to check if I had missed something. Thanks.
[2018-01-29 22:59:34] |
Yes refer to the Horizontal Lines study: Horizontal Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
