Date/Time: Sun, 04 Oct 2026 07:48:24 +0000
Will a chart study check every tick?
View Count: 1289
| [2018-01-29 21:02:00] |
| CustomIndicators - Posts: 126 |
I have a custom study (the bot) that checks a custom study on each of 21 charts (the oscillators). On the smallest charts, such as a 5 tick chart, I often see a signal go by, but the bot doesn't seem to catch it. So, I want to understand how this is working in SC. Should a study be checking every single tick that goes through the market, or is there a set time that the chart must wait before allowing another tick to be processed by a study? If there is a time that a chart must wait before processing a tick, is there a way to have a study on a chart (or, that chart entirely) to process every tick, while other charts (big charts) not have to process every tick? |
| [2018-01-30 04:32:37] |
Refer to the documentation here for this: Working with ACSIL Arrays and Understanding Looping: Update Study Function Calls We cannot provide any further information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
