Date/Time: Sat, 18 Jan 2025 19:21:30 +0000
Zig Zag Cumulative volume indicator
View Count: 2276
[2018-01-29 19:46:30] |
Glenn Infinity - Posts: 103 |
can you help me on an audio alert condition if I want one to go off when the direction changes
[2018-02-28 22:35:22] |
We assume you mean when the Cumulative Volume resets, since you reference the Zig Zag Cumulative Volume study. In order to do this, use the following alert formula for the study: SG5 < SG5[-1] You can find the documentation for entering an alert on a study here: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study Also be sure to have the following options active: - Enabled - Reset Alert Condition on New Bar - Alert Only Once per Bar - Evaluate on Bar Close You can find the documentation for these options here: Study/Chart Alerts And Scanning: Alert Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-01 17:23:18] |
John - SC Support - Posts: 37327 |
We have also setup a Study Collection that has this alert already set on the Zig Zag Cumulative Volume Study. You can find this here: https://www.sierrachart.com/AdditionalFiles/ZigZagCumulativeVolumeResetAlert.StdyCollct For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
