Date/Time: Sat, 18 Jan 2025 04:58:47 +0000
ESH8 scid data
View Count: 763
[2018-01-29 17:55:34] |
User716661 - Posts: 13 |
I am encountering a problem with the ESH8.scid file (missing days). Could you check the file please? Thanks |
[2018-01-29 19:07:53] |
We see you are using Rithmic. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-29 19:08:21
[2018-01-29 19:10:43] |
issue solved Thanks
