Date/Time: Sat, 18 Jan 2025 05:17:28 +0000
Chart DOM Vertical Line Grid
View Count: 1176
[2018-01-29 06:36:45] |
Logan W - Posts: 28 |
Is it possible to have a vertical line grid on the Chart DOM? If not, can this option be implemented? Thank you in advance. |
[2018-01-29 21:23:20] |
Refer to: Global Trade Settings Windows: Show Market Data Column Vertical Lines (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
