Date/Time: Mon, 21 Apr 2025 13:14:36 +0000
[User Discussion] - chartbook default on start
View Count: 4839
[2018-01-28 20:20:31] |
kinghat - Posts: 120 |
i have read where you can change the order of chartbook tabs by setting them in general settings: Chartbooks (Workspaces): Automatically Open a Chartbook but i want to keep the order they are in but set a default chartbook to be displayed after loaded. i personally want my first chartbook in the list viewable after start. it currently is starting with the last loaded in the list. you could change it so the first loaded in the list to be the one viewed or you could just let ppl set a default to be viewed after start as some people might want to have the order in one way but view a certain chartbook on start.
[2023-05-16 23:33:31] |
User708541 - Posts: 135 |
This is a good question. The reason it has no response is because it was posted as a User Discussion.
[2023-05-17 13:34:11] |
John - SC Support - Posts: 39362 |
There is not an option for choose the first loaded versus last loaded chartbook as the active chartbook.
[2025-02-25 20:37:44] |
User739278 - Posts: 1 |
Try Global settings General settings tab opens Startup section (2nd one down) Click in 2nd column (Select files to open On Startup) Click add - Add your .cht Click remove - delete the one you don't want OK |
