Date/Time: Sat, 18 Jan 2025 05:19:29 +0000
attach windows
View Count: 1158
[2018-01-27 16:49:31] |
pnlcheck1 - Posts: 6 |
Is there a way (or may I suggest) the ability to attach windows like the orders and positions, watchlists, and chart values windows to the main SC window? thanks |
[2018-01-27 20:24:58] |
No, this is not supported. It is not a suggestion we would take. It is very complex to implement that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-28 02:35:23] |
Xfanman1 - Posts: 320 |
Try Aquasnap, it works well with SC and it's free for personal use. The paid version adds some additional functionality for a reasonable price (Multi-Monitors, their Magnet function). It makes organizing your charts and platform window very easy. One quirk appears to be that the SC Chart windows act as a group within AquaSnap and the Quote, CVW and other windows behave as a different type of group. Experiment with it and you'll see what I mean. https://www.nurgo-software.com/products/aquasnap Scott Date Time Of Last Edit: 2018-01-28 02:41:39
[2018-01-28 03:00:20] |
Interesting. Did not know about this.
