Date/Time: Mon, 10 Mar 2025 13:31:10 +0000
Linking charts in a chartbook
View Count: 7541
[2018-01-27 13:55:20] |
User27542 - Posts: 20 |
Hello, I'm sure this is relatively easy to do, but could you tell me how to link charts in a chartbook? If I scroll back in time on one chart I want the other charts to scroll back automatically at the same time. For instance, suppose I have charts A,B and C. When I scroll back to 7.30 am, say, on chart A I would like charts B and C to be scrolled back at the same time. With thanks in advance for your help. tme246 |
[2018-01-27 20:50:35] |
This is explained here: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-30 15:48:23] |
Baulin - Posts: 2 |
Doesn’t work!
[2022-03-30 17:15:36] |
John - SC Support - Posts: 38516 |
You need both charts to have the same link number and both of them to be set to have the "Scroll Position" enabled.
