Date/Time: Sat, 18 Jan 2025 05:10:26 +0000
Winsock Initialisation & Shutdown
View Count: 1033
[2018-01-27 11:33:36] |
Pinger - Posts: 33 |
Hi I want to send data out of SierraChart via a socket to do some external charting. I've put the Winsock initialisation code (WSAStartup(), socket(), etc) in my study sc.SetDefaults block, and this appears to be working. My query is, where to put the shutdown code (socketclose() and WSACleanup()) to ensure everything is shutdown nicely when my study is removed from a chart. Is there a function that is called when a study is removed from a chart to put such code? Kind regards |
[2018-01-27 21:51:57] |
Refer to: ACSIL Interface Members - Variables and Arrays: sc.LastCallToFunction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
