Date/Time: Sat, 18 Jan 2025 05:02:01 +0000
Sub instance problem
View Count: 863
[2018-01-26 20:27:42]
User193533 - Posts: 1
When i use sierrachart in subinstance mode, same instruments doesnt refresh after few minutes. both server and client side.
best regards
Peter
imagesubinstance problem.png / V - Attached On 2018-01-26 09:57:54 UTC - Size: 15.49 KB - 271 views
[2018-01-26 22:11:12]
As long as you know the market is active at the time you do not see a symbol update, then reconnect to the data feed following these instructions:
If that causes the data feed to resume, then this indicates a data feed problem from CQG.
