Date/Time: Sat, 18 Jan 2025 05:18:43 +0000
My NG market chart is not working
View Count: 668
[2018-01-26 20:03:48] |
User619 - Posts: 6 |
I don't get any markers when I buy and sell, my ticks on the side are not accurate. I've tried to close it, reopen, delete the chart, add a new chart, move from March to April and nothing can fix this problem. Please advise! Is this a sierra chart issue or data issue? My friends who all use the same settings as me are not having this problem only I am as of this morning. Thanks! |
ngmarket.png / V - Attached On 2018-01-26 20:01:48 UTC - Size: 96.16 KB - 269 views Attachment Deleted. |
[2018-01-29 20:04:47] |
1. The Symbol Settings for the chart are not correct. Follow these instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts 2. In regards to not seeing order fills on the chart, refer to: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Could be that your computer's clock is not set accurately. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
