Date/Time: Sat, 18 Jan 2025 05:05:25 +0000
Historical Stock charts
View Count: 949
[2018-01-26 18:22:07] |
wingz - Posts: 121 |
Is the data on your Historical Charts price adjusted over time in any way? Like dividend adjusted price or anything like that? For instance.....if I was to go back two or three years and look at the low price for the day on a particular stock, on a certain day......is that the actual low and high price of the stock that day or has it been adjusted in any way? Thanks.
[2018-01-26 18:55:11] |
Refer to this particular section about this: http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#DifferencesWithHistoricalDataDueToDividendAdjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
