Date/Time: Sat, 18 Jan 2025 05:07:52 +0000
VP - Multiple profiles based on fixed time
View Count: 895
[2018-01-26 15:42:30] |
User33743 - Posts: 83 |
Hi, If I setup Volume graph period type to Multiple profiles based on fixed time, volume on profile is "Static" what means that even i scroll back 1hour chart back i still see volume for all sesion. Is this possible to make it that volume would be presented only from begining of sesesion to actually last candle/bar presented on chart? It works for "visible bars" but there is no session time. Could you help? Best Regards |
[2018-01-26 18:28:01] |
If I am understanding you correctly, you would be looking for a setting that would be something like From Session Start Time to Last Bar on Screen. There is no way to do this with the study. The Visible Bars Volume Graph Period Type is the closest that accomplishes this, as it only based on the bars that are on the screen at that time. The Period Type of From Session Start Time to End is another type that is close to what you are looking for. You can find the information on this period type here: Volume By Price Study: From Session Start Time to End Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-26 18:28:39
[2018-01-30 20:10:26] |
TY you for reply. Best Regards |
