Date/Time: Sat, 18 Jan 2025 05:07:52 +0000
Adjusting the LINE indi values when rolling over
View Count: 1101
[2018-01-26 15:21:16] |
User97684 - Posts: 136 |
Every three months I have to manually adjust the values inside the line indicator for all these lines for the new rolled over symbol. ( add / subtract the tick diffrence - like back adjusting ) Is there a way to connect the lines to the symbol, so rolling over changes the values with the relevant tick difference ? http://www.sierrachart.com/image.php?Image=1516979969690.png Many thanks |
[2018-01-26 18:03:25] |
If those lines are from a study, the answer is no.
