Date/Time: Sat, 18 Jan 2025 05:00:05 +0000
Dax // Problem Daily data
View Count: 1016
[2018-01-26 11:12:29] |
User00111 - Posts: 111 |
Dear Sir, please check the pictur attached. Why the daily chart have data hole ? Regards. |
DAX_Daily_No data.png / V - Attached On 2018-01-26 11:07:24 UTC - Size: 102.37 KB - 380 views DAX_840_Ok.png / V - Attached On 2018-01-26 11:07:31 UTC - Size: 104.27 KB - 351 views |
[2018-01-26 18:41:41] |
This is what we see for that DAX futures symbol: http://www.sierrachart.com/image.php?Image=1516992066169.png Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-26 18:42:43
[2018-01-26 19:26:42] |
I can not make it
[2018-01-27 23:24:17] |
Very unusual. Not sure why there is blank space there. Provide this chart following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
