Date/Time: Sat, 18 Jan 2025 04:56:06 +0000
[User Discussion] - compact tool values windows
View Count: 1254
[2018-01-25 19:47:31] |
User459170 - Posts: 262 |
Is there a way to choose different colors for the open, high, low values in the Compact Tool Values Window? THanks
[2018-01-29 16:48:07] |
Hi all, Is this feature not available? Any help please? |
[2018-01-29 18:38:16] |
No.
[2018-01-29 19:22:54] |
Thanks. Do you think it would be possible for you to include this feature perhaps in a future version?
[2018-01-29 19:57:00] |
No definitely not but there is sort of an indirect way of doing this now. If you use the Overlay (Bar) study: Overlay - Bar And overlay the same chart and set it to display as the main price graph, then you can control the colors of the chart bars as documented here: Color Settings for Graph Draw Types Those same colors will then be used in the Chart Values Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-29 20:43:25
[2018-01-29 20:11:33] |
Interesting workaround.
[2018-01-29 20:13:11] |
Is this memory intensive?
[2018-01-29 20:44:00] |
Post #5, had a missing link and in one section we gave the wrong link. This is now all corrected. Reload this page. The answer to post #7 is no. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
