Date/Time: Sat, 18 Jan 2025 05:11:16 +0000
BitMex order questions
View Count: 714
[2018-01-25 18:01:46] |
onnb - Posts: 662 |
1. Which SC order types are supported with the BitFinex api? We are using Stop/Limit/Market but do you also support other order types like StopLimit, MIT or any others? 2. Is there support for Server Side OCO's? |
[2018-01-25 18:35:04] |
1. Bitfinex or BitMEX? All order types that Sierra Chart supports are supported long as they do not get rejected by the exchange. You just have to try and see. 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
