Date/Time: Sat, 18 Jan 2025 05:08:26 +0000
Can open only 22 Chartbooks now before it was more
View Count: 763
[2018-01-25 10:51:20]
User134797 - Posts: 52
Hi All,
When I first start to work with Sierrachart in Jan2016 it was possible to open more than 30 Chartbook.
Now I can hardly open 22 Chartbook, example: if I open Chartbook 23 some chart in the Chartbook are empty. Sometimes Sierrachart stops working so I have to close Sierrachart or it close by it self.
Info:
Data range in Sierra is from 2016-01-11 to 2018-01-25, Days to load are 30.
Can somebody explain how to solve this problem, by the way I have more than enough memory is my desktop system.
Regards,
Iwan
[2018-01-25 18:50:01]
Enable this option as explained:
General Settings Window: Destroy Chart Windows when Hidden (Global Settings >> General Settings >> GUI >> Application GUI)
And use multiple instances of Sierra Chart:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
