Date/Time: Sat, 18 Jan 2025 05:01:17 +0000
User Question
View Count: 747
[2018-01-24 23:02:29] |
Sierra Chart - Max - Posts: 5779 |
The USDX seems to be the correct chart with correct values for the US Dollar Index; however, the other currencies; GBP-X and so on do not seem to be the charts or correct values for the rest of the currency indexes.
I attached a screen shot below of GBP-X on Sierra. Its the last image. The first image comes from choosing the instrument to download and the second image is from Sierra Charts user manual. Please advise. Sierra Chart Support |
[2018-01-25 17:57:01] |
For how the currency indexes are calculated, refer to: Sierra Chart Market Statistics: Forex Indexes Calculation This may be different than the other source your comparing to. It does not mean they are incorrect. It just means the calculation and reference point is different. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
