Date/Time: Sat, 18 Jan 2025 05:09:36 +0000
CLeaning Data File
View Count: 1695
[2018-01-24 22:35:02] |
User23815 - Posts: 210 |
How do I clean my data file? It has become huge. But it has symbol data from charts that I no longer follow. Also old contracts. I didn't realize it was building and never deleting as I rolled or stopped following. In my Sierra Chart Data folder it appears that there are dly and scid files outdated or not used. The scid files are large and taking the space. I went through documentation but didn't see what I wanted and don't want to delete files from the folder and have it create a program problem. Thanks
[2018-01-25 02:24:31] |
Refer to: Chart Data and Chart Data Files: Deleting a Chart Data File and don't want to delete files from the folder and have it create a program problem. You will not a create a problem doing this.
