Date/Time: Wed, 29 Jan 2025 20:33:08 +0000
[Programming Help] - Spreadsheet Buy signal one time until next sell signal.
View Count: 1038
[2018-01-24 20:58:22]
User252419 - Posts: 235
How can I see only 1 Buy Signal until next Sell Signal? Instead of viewing multiple Buy Signals while the Sell Signal does not appear.
I'm using a Spreadsheet System/Alert, Buy Entry and Sell Entry Columns.
Thank you
Date Time Of Last Edit: 2018-01-24 21:02:25
[2018-01-24 21:23:05]
Sawtooth - Posts: 4163
You need to use an additional Formula Column to create a persistent 1 with the Buy signal formula, then release it with the Sell signal formula, e.g. in cell P3:
=IF(yourbuyconditions,1,IF(yoursellconditions,0,P4))
Then in K3:
=AND(P4=0,P3)
And in M3:
=AND(P4,P3=0)
This is a simplified solution; your specific situation may require modifying this concept.
[2018-01-25 10:22:05]
Thank you very much @tomgilb! It works great! Would it be possible to talk with you? Do you work for SC?
Thank you!
[2018-01-25 14:57:43]
I do not work for SC. I am a futures trader and an independent consultant.
You can contact me here:
https://www.sawtoothtrade.com/contact.html
