Date/Time: Sat, 18 Jan 2025 05:01:15 +0000
Trade Activity Log Has Incorrect TimeStamp On Export
View Count: 993
[2018-01-24 19:21:01] |
User240019 - Posts: 112 |
For SIM this has always been the case, but wasn't always with live trades. Now it's true for both and my global time setting is for Chicago, CST. What do I need to do to adjust? |
[2018-01-24 19:23:29] |
I might also add, in the export window, they are correct but in the file they are not.
2018-01-24_1323.png / V - Attached On 2018-01-24 19:23:26 UTC - Size: 57.82 KB - 371 views |
[2018-01-24 23:21:17] |
File >> Export will always export using UTC times. You need to use File >> Save Log As instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-24 23:21:27
