Date/Time: Sat, 18 Jan 2025 04:58:54 +0000
ES data feed
View Count: 847
[2018-01-23 21:24:13] |
User669396 - Posts: 7 |
I have a CME non professional data feed service package activated paying the $93 and I was getting data for ES SP500 futures fine. I then signed up for a topstep trader combine, which uses CTS T4 fix on Sierra chart. Now I cant get the ES SP500 futures data feed. Opening up a chart I get data up until 23/01/18? Can this be fixed |
[2018-01-23 22:07:01] |
What is the exact symbol of the chart? We will also look at your Message Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-23 22:07:10
[2018-01-25 21:18:07] |
Hi I'm trying to get my data feed working for SP.20180300.CME_Eq I ve paid my service balance. Currently I can only get data for the overnight session on an intraday chart. Ive tried changing settings and tried setting it to not using the evening session??? |
[2018-01-25 21:23:47] |
That symbol hardly trades. The symbol you want to use is: ES.20180300.CME_Eq Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
