Date/Time: Sat, 18 Jan 2025 04:56:19 +0000
zigzag indicator
View Count: 1389
[2018-01-23 20:13:17]
User635423 - Posts: 51
Is there a way to change the zigzag indicator reversal amount from percentage to points or ticks?
Thanks,
[2018-01-24 18:02:57]
Yes. You need to use Calculation Mode 2 or 3, and then the calculation will use the value set in Reversal Amount for Calculation Mode 2,3. This is documented with the Zig Zag study, which can be found here:
Zig Zag: Calculation Modes 1 and 3
