Date/Time: Sat, 18 Jan 2025 04:59:36 +0000
Tool Config - Retracement tool
View Count: 1248
[2018-01-23 12:02:25]
nicktrader - Posts: 729
I am working with two instances.
The second instance do not save the config of the "Retracement tool". Each time I save it as "TC1" but in use it gives back the config of "TC8".
[2018-01-23 17:47:01]
You have the TC8 configuration selected as the configuration for the Retracement Tool. Select TC1 as the configuration you want. You can find the documentation for how to do this here:
Chart Drawing Tools: Drawing Tool Configuration
[2018-01-24 06:01:09]
I know what to do (i.e. Global Settings/ Toll Configs/...) I saved it in Instance 1 with the TC1 config. But if I'd like to draw I get the TC8 config.
The problem is only in Instance 1.
[2018-01-24 06:04:44]
After you select the drawing tool from the Tools menu, how do you have Tools >> Current Tool Configuration set?
