Date/Time: Sun, 24 Nov 2024 03:56:55 +0000
High Memory Usage
View Count: 1670
[2013-09-23 16:27:43]
kleros - Posts: 21
I am using version 1025. On my machine today, Sierra is very sluggish. According to Windows Task Manager my physical memory usage is 97% of total 3,965MB of RAM. I see that SierraChart.exe is only using 42,808kb of memory. Sierra is the only application running. I believe that Sierra usually uses 30-40% of physical memory. I have not changed anything since using the application on Friday. I have re-booted multiple times and the memory usage is still high. Please help.
Chris
[2013-09-23 16:49:19]
Refer to help topic 30 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails30.html
According to what you are seeing Sierra Chart is using 42 MB of memory. This is reasonable.
