Date/Time: Sat, 18 Jan 2025 02:04:26 +0000
Chart DOM Cumulative Last Size Text/Background Color
View Count: 1786
[2018-01-23 01:56:46] |
Logan W - Posts: 28 |
After four seconds on a price, the cumulative last size text and background colors reverts to the chart background and values colors. This creates an issue when using different colors for the chart and the chart DOM. Is there a way around this or can you add a specific option for this in the graphic settings? Date Time Of Last Edit: 2018-01-23 01:58:47
[2018-01-23 04:30:43] |
We are going to disable this in the next release until we determine how best to implement this. This was requested by one particular user. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
