Date/Time: Sat, 18 Jan 2025 01:52:43 +0000
How to restore candles that disappear to left of chart?
View Count: 970
[2018-01-22 23:56:22] |
WilliamA - Posts: 26 |
Sometimes when scrolling around on a chart I lose all candles to the left of the chart. I can't use the palm to pull them back to the center of the chart. How can I restore the chart view please? I've tried Alt+Shift+R but that doesn't do it. I'm not even sure what NOT to do to avoid causing the problem over and over again. I've been deleting charts and building a new one but then I've lost all my previous drawings.
[2018-01-23 00:47:16] |
Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
