Date/Time: Sat, 08 Feb 2025 14:23:37 +0000
Numbers Bars question / proposal (ln:82) (ln:74)
View Count: 1090
[2018-01-22 19:16:49] |
User525997 - Posts: 20 |
Hello, I have 1 question and 1 proposal for the Numbers Bars indicator. 1. Question: Is it possible to change the thickness of the "Open To Close Boxes" (ln:74)? How would I do that? 2. Proposal for Numbers Separator Character (ln:82): I would like to have the option "Space x Space". At the moment there is only the option "x" which has a squeezed look imo. Thank You. |
[2018-01-22 20:18:46] |
This will be reviewed later on.
[2018-03-06 18:38:29] |
John - SC Support - Posts: 37842 |
1. It is not possible to change the Width (thickness) of the Open to Close Boxes. We have looked at the amount of work it would take to make this an available option, and it is enough involved that it is not something we will be doing at the moment. 2. This has been added and is available in the latest release. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-11 09:25:55] |
ycomp - Posts: 321 |
where can I find this option?
[2020-07-13 14:01:32] |
Refer to this setting: Numbers Bars: Numbers Separator Character For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
