Date/Time: Sat, 18 Jan 2025 01:48:35 +0000
[Programming Help] - TRADING SYSTEM
View Count: 653
[2018-01-22 18:52:57] |
User82615 - Posts: 106 |
HELLO I'M STARTING TO PROGRAM MY OWN TRADING SYSTEMS USING ACSIL AND I HAVE A QUESTION : THIS TRADING SYSTEM WHEN SOME RULES ARE ACOMPLISHED IT LAUNCHES A BUYENTRY MARKET ORDER , AND THEN IT SIMULTANEOUSLY LAUNCHES AN ATTACHED STOP ORDER THAN IS SOME TICKS AWAY FROM THE PARENT ORDER. UNTIL HERE EVERYTHING IS RIGHT , BUT THEN AFTER THIS (AND ONCE I'M LONG IN A POSITION ) I WOULD LIKE TO SEND A BUY EXIT LIMIT ORDER BUT NOT AN ATTACHED ORDER IT WOULD BE A BUY EXIT LIMIT ORDER THAT WOULD BE IN A 20 MOVING AVERAGE OF THE CHART , BUT I WOULD LIKE THAT THE STOP ATTACHED ORDER WILL NOT BE CANCELLED WHEN THIS BUY EXIT LIMIT ORDER IS SENT . WOULD THIS BE POSSIBLE TO PROGRAM ? IF SO COULD YOU GIVE ME A HINT OF WHAT STEPS TO FOLLOW TO PROGRAM IT USING ACSIL PLEASE ? BECAUSE THE PROBLEM IS THAT WHEN THE BUY EXIT LIMIT ORDER IS SENT IN CANCELLS THE ATTACHED STOP ORDER THAT WAS SENT EARLIER. THANK YOU VERY MUCH FOR YOUR HELP |
