Date/Time: Mon, 25 Nov 2024 05:24:07 +0000
Backtest Multiple Symbols
View Count: 1250
[2018-01-20 20:50:20]
User279534 - Posts: 4
As far as I can tell you can only do a bar-based back test on a single symbol at a time. Is there anyway to perform the test over multiple symbols without having to manually change the chart? For ex., get the backtest to run through all the symbols in a watchlist?
[2018-01-20 23:25:55]
We will add this capability.
[2018-01-21 05:03:01]
This is now done and working and will be out in the next release.
[2018-01-30 03:13:05]
OK, thank you!
[2019-01-28 05:10:38]
User556932 - Posts: 31
Can you please reply with the link for instructions how to perform a bar based backtest for multiple symbols (eg from a watchlist).
Thanks in advance
[2019-01-29 05:45:26]
This is documented here:
Trade Menu: AutoTrade System Bar Based Backtest with Scan (Trade menu)
